Author Topic: I am not able to understand the operation of CC CV using LM723 IC  (Read 1358 times)
Offline audioTopic starter
  • Country: in
Hi all,
           we have LM723IC in our curriculum. When it comes to practical design of CC CV power suppy using LM723, I cant understand how it current limitation are designed. there are two IC in the circuit.
There is voltage divider feeding it to the opamp inside IC723. I have attached the schematic for reference.
Thank you all.
« Last Edit: July 10, 2023, 12:58:57 pm by audio »
Offline iMo
  • Country: bt
Re: I am not able to understand the operation of CC CV using LM723 IC
« Reply #1 on: July 10, 2023, 02:05:29 pm »
The only way how the current limit might work in that schematics (provided nothing is missing there) is the U2 is sensing a voltage drop at the Vcc of the U2 - with the load the Vcc starts to drop and the U2 works like a comparator.
The voltage of U2's Vref is divided to something around 0.9V what is too low for normal 723 operation, imho, thus they may leverage some nonstandard 723 behavior..
PS: there could be some hysteresis introduced by the dividers around U2 such the U2's output will not oscillate around the set current limit..
« Last Edit: July 10, 2023, 02:47:04 pm by iMo »
The following users thanked this post: audio
Offline dobsonr741
« Reply #2 on: July 10, 2023, 05:07:13 pm »
Something is missing from the schematics. Perhaps the subject of the homework is to add the missing components?
This is how I would go about doing it:
First, I would figure out the acceptable input range of the error amplifier.
Then add a probably high side current sensing shunt.
Online xavier60
« Reply #3 on: July 10, 2023, 07:08:36 pm »
The low-side CS resistor would be between the bottom end of R31 and the bottom end of R32.
The mess connected to REF, IN- and IN+ is to apply some voltage to both inputs to satisfy the common mode input range for the internal opamp and also a variable offset difference to set the CC threshold.
HP 54645A dso, Fluke 87V dmm,  Agilent U8002A psu,  FY6600 function gen,  Brymen BM857S, HAKKO FM-204, New! HAKKO FX-971.
Offline iMo
  • Country: bt
« Reply #4 on: July 10, 2023, 08:05:40 pm »
It could be the shunt has been made of a PCB trace, therefore the shunt is missing there in the schematics..
  • Country: in
« Reply #5 on: July 11, 2023, 12:59:04 pm »
Hi all,
Suggest me some circuit which could do regulation for 0-30v and 0-3ampere.
Thankyou all.
Online xavier60
« Reply #6 on: July 11, 2023, 04:03:23 pm »
Hi all,
Thankyou all.
Not certain what your skill level is. A few members and myself have built very similar versions of this, https://www.eevblog.com/forum/beginners/lm324-power-supply-with-variable-voltage-and-current/msg3582664/#msg3582664
Even at 3A, tap changing should be included. With my build, I have the unregulated supply including relay on a separate PCB.
« Last Edit: July 11, 2023, 04:06:15 pm by xavier60 »
Offline StacyHaward
  • Country: mu
    • youpijobs
« Reply #7 on: August 22, 2023, 09:10:44 am »
A voltage divider is often used to provide voltage feedback to the non-inverting input of the internal operational amplifier of the LM723. This allows for comparing the actual output voltage with a fixed reference voltage, enabling the regulator to maintain the desired output voltage.
cv assistant juridique
« Last Edit: January 09, 2024, 09:05:49 pm by StacyHaward »
