Of course there are improvements to be made, but if the circuit does what it is intended to do and the chance of failure or injury is anything less than 100% then there is nothing ‘wrong’ with the circuit.
I'd rather turn that around and say if the chance of failure or injury is higher than 0%, then there's a lot wrong with the circuit.
Just to mention a couple of points:
There's no current limiting resistor to the circuit. If it's turned on at the voltage crest: Wham! You can probably say good bye to the 1N4007s, what burns next is anyone's guess.
There's no bleed resistor across the series cap. If you pull the plug and accidentally touch the prongs, you will potentially receive the discharge of a couple of 100 volts from a 2.2 uF cap. No fun, I assure you.
And so on.
Designed by an amateur and potentially lethal.
