Author Topic: Datasheet Formula Confusion  (Read 831 times)
Offline ruumooTopic starter
« on: December 06, 2018, 06:29:13 am »
I'm designing a Li-Ion charge controller around the LT1513 ic. I want to use the given application circuit, but I want to use more charge current than in the example, but I can't figure out how to calculate IR5 for the charge current formula. IFBVOS is given as 2.5mV (It actually stands for Voltage Ofstet of IFB)
« Last Edit: December 06, 2018, 07:14:40 am by ruumoo »
