Author Topic: Precise and stable ULF oscillator  (Read 1334 times)
Online ricko_ukTopic starter
« on: January 08, 2020, 02:57:39 am »
what is the best way to generate a ULF oscillator with the following characteristics:
1) square wave output (or sine (then I can square it with a comparator)
2) user selectable frequency between 5 Hz and 7 Hz (can be tuned manually with a trim-pot or any other way)
3) as stable as possible
4) without using higher frequencies "counted down" or micros. This is important because I don't want to have harmonics which are not either the fundamental or odd harmonics (i.e. square wave at the fundamental frequency)
I have looked at some of the simple not-gate oscillators or similar ones but in various forums/web-pages they say their stability is poor.
Any suggestions/tips?
Thank you :)
Offline unitedatoms
Re: Precise and stable ULF oscillator
« Reply #1 on: January 08, 2020, 04:02:48 am »
Fairly accurate epilepsy inducer can be made with TLC555 chip. Look for capacitors with temperature coefficient stated in datasheets. The rest of components other than trimpot is not too critical.
Interested in all design related projects no matter how simple, or complicated, slow going or fast, failures or successes
Offline schmitt trigger
  • Country: mx
« Reply #2 on: January 08, 2020, 04:13:41 am »
Hmmmmmm......
Would you kindly elaborate on your requirement #4 ?
I am not following the “no even harmonics” bit.
This is a serious question, I am not being sarcastic.
Offline fourfathom
« Reply #3 on: January 08, 2020, 04:19:52 am »
Do you have a specification for the spectral purity of this ULF square wave?  You can get *extremely* close to perfect using simple digital generator designs.  Add an analog low-pass filter to an appropriate digital design and I defy you to measure *any* spurious output signals.  If you go digital, then you have the stability requirement solved.
We'll search out every place a sick, twisted, solitary misfit might run to! -- I'll start with Radio Shack.
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #4 on: January 08, 2020, 09:15:14 am »
Funny thing is, even a "magic sinewave" can have tons of transitions (it looks very square, or, well, pulsed at least) but can null arbitrarily many harmonics.  In the limit, it approximates PWM, which has no spectral content between BW and Fclk - BW, where BW is the signal bandwidth and Fclk is the switching (modulation) frequency.
Heh, hmm, I wonder if you can further tweak PWM to null an arbitrary amount of the lower sideband, thus extending the stop band from BW to Fclk.  Any SSB modulator should do, I think... adapted from PWM output, of course.  Wouldn't be very useful but would help push high frequency content up just a little bit further, allowing a slightly smaller filter.  Assuming one needed a class D amp to deliver wide bandwidth (like audio) that also must meet EMC requirements (which they never do, so..). ;)
Regarding stability and trimmability: pick one.  Trimmers are shite.
Seven Transistor Labs, LLC
Offline Benta
« Reply #5 on: January 08, 2020, 05:50:37 pm »
Hmmmmmm......
+1 to this question. A divided-down crystal oscillator should provide a perfect square wave, depending on your design of the final stage.
Offline edpalmer42
« Reply #6 on: January 08, 2020, 06:12:03 pm »
You have to do better than that.  Do you need parts-per-thousand or parts-per-billion stability?
Same problem as #3.  What level of harmonics can you tolerate?
Online Kleinstein
« Reply #7 on: January 08, 2020, 06:37:55 pm »
The easy way is a stable higher frequency and divide down. One can remove the clock coupling to a very high degree if really needed. If really needed the divider could be twice an odd number, so that there would be only the very high clock or odd harmonics.
Without a divider the on/off ratio will not be very good - so even if not using a divider there will still be even harmonics. Chances are good just a simple divider would get the much better square wave, with less of the even harmonics.
Offline AG6QR
    • AG6QR Blog
« Reply #8 on: January 08, 2020, 06:38:12 pm »
Agreed. Furthermore, what kind of stability are you talking about?  Long-term drift,  short-term phase noise/jitter, or are there requirements somewhere in the intermediate term?
A GPS disciplined oscillator can have virtually no long-term drift, but it's impossible to completely eliminate short-term instability.  Like in many other situations, spending more money lets you approach perfection more closely, but each step is much more expensive than the previous.
Offline fourfathom
« Reply #9 on: January 08, 2020, 07:13:56 pm »
The OP is looking at a freq range from 5 to 7 Hz, and contemplating analog tuning, so I doubt if the picosecond jitter of a GPS clock would be an issue.  Give the OP a 10 MHz xtal, and follow that with a divider in the 700000 to 1000000 range (output = 14.28xxx to 10 Hz).  Follow that by a div by 2 and he has a damn near perfect square wave with approximately  0.2 ppm frequency tuning resolution (accuracy depending on the xtal).  You can probably do that with a dirt-cheap PIC internal counter.
Need something different?  We've got NCOs, fractional dividers, noise shaping, hybrid analog/digital PLLs, etc.  The bag of tricks is deep.
But given the vague requirements, I have no idea what level of sophistication or performance is actually called for, although I suspect not much.
Offline atmfjstc
« Reply #10 on: January 08, 2020, 07:28:03 pm »
I'm more curious about the OP's application. What use could one have for a 7Hz square wave? Doubt it's for audio - it would sound like crap. Drive a LED or a solenoid? Then why worry about the harmonics?
Offline unitedatoms
« Reply #11 on: January 08, 2020, 08:06:43 pm »
1. Miniature device for bridges demolition
2. Standing wave actuator for liquid mercury tank for gold mining industry
3. Acoustic emitter for subliminal fear in crowd control situations
4. Ikea furniture flexibility demo setup
Online Circlotron
