Author Topic: Inductor color code?!  (Read 547 times)
Offline DrHumbertoTopic starter
« on: February 20, 2022, 06:03:12 pm »
Hi everyone,
this is my first post here and I hope I set it in the right category. I am working on an older oscilloscope at the moment. A Philips PM 3340. The Power Supply is down, I have figured out some defect components by now for example bad npn power tranni and a high voltage diode and... maybe an inductor. Here is my problem by the look of it I am pretty sure it is an inductor but what value? I looked through the common color code charts but couldn't find this color combination. White Blue Green , so 9 | 6 | and then? Green as a multiplier seems very high to me and is listed nowhere on the color code charts.
Can anyone help me?
Offline ledtester
Re: Inductor color code?!
« Reply #1 on: February 20, 2022, 07:08:47 pm »
Could the white band actually be silver (x0.01)?
« Reply #2 on: February 20, 2022, 07:19:58 pm »
That would make sense, thought so too, I rechecked it now with different type of lights :D it is still pretty damn white... and all in all in terms of color the component looks in good shape. What can't be seen on the picture is that it is a little out of shape ( bubbly beany) that is the reason I would like to check the value of it but without knowing what value it should be.. nope
Offline Benta
« Reply #3 on: February 20, 2022, 07:26:40 pm »
More likely a 5.6 pF tubular ceramic cap. That would explain one end being thicker.
Offline madires
  • A qualified hobbyist ;)
« Reply #4 on: February 20, 2022, 07:27:28 pm »
That seems to be an old marking method with two bands for the value (56µH) and one band for the tolerance (silver = 10%). White wouldn't make any sense as multiplier, nor as tolerance.
« Last Edit: February 20, 2022, 07:30:39 pm by madires »
