Just to recap, the datasheet says that the maximum voltage on an input is the same as the low-power supply voltage. E.g if you’re running it on 3.3V, then you can apply up to 3.3V on an input, but if you’re running it on 3.0V, then you can’t apply more than 3.0V on an input.
The commenter said the module uses a supply voltage of 1.8V. But the datasheet says the IC needs 2.4V minimum to operate. So either the commenter is wrong, or the commenter had a faulty module, or the commenter was using too low an input voltage to the module (such that the regulator can’t regulate properly, or the module (for some inexplicable reason) is under powering the chip on purpose.
My guess would be that the commenter is wrong.
