So I have a "Densha De Go!" arcade cabinet and I have come to find that a critical indicator light (0.3 amp 12V Incandescent Bulb) is not illuminating when commanded.
Testing revealed that the negative wire was sat, but I get nothing on the 12V+ wire. (I had this wrong, the NEGATIVE wire is the dead one) Tracing it back to the board sets I narrowed it down to a specific PCB. (I am unable to find any repair manuals or schematics as everything is in Japanese, so I'm sort of winging it here.) Anyway, I believe I am on the right board... I started inspecting for failures and came across a TD62064APG that had clearly been swapped out as I see some solder blobs and naked pins. My first urge was to repair the solder job, but I have a few things I am unsure about...
First, am I correct in assuming that you would use this IC to drive a low voltage lamp, and am in the right area?
Second, it appears that the "G version of this IC is quite similar to the original version, and looking at the datasheets I'm not sure what the difference even is... My first instinct is to find the original IC and replace this with a new one to ensure that this one isn't fried, fix the missing solder, and have the original part number in there, just to be extra safe.
Input?
(Thanks BTW)
