The DC bus voltage of my motor is 48V, and the parameters are as follows:
Continuous Current: Adc --> 12.00 | Arms --> 10.00
Peak Current: Adc --> 40.00 | Arms --> 30.00
Rated Cont Power: Watts --> 350
Speed at Rated Power: RPM --> 2400
Design Voltage(Rated voltage): Vbus --> 48.0 (Vdc) | Vac --> 34(Vrms)
Back EMF at Temp: Vpk / kRPM -->18.5 | Vrms/kRPM --> 13.0
Back EMF: Vpk / kRPM --> 19.0 | Vrms/kRPM -> 14.0
Motor Constant at 25°C: N-m/√watt --> 0.28 | oz-in/√watt --> 39.5
Inductance: Lm --> 0.55
Then when I was designing the drive, I needed to choose an NMOS. I saw ON Semiconductor, but when I was reading the datasheet, I was confused. For example: the datasheet of this product FDMS86101DC, the first sentence says:
MOSFET-N-Channel,POWERTRENCH, DUALCOOL 56 Shielded Gate 100 V, 60 A, 7.5 m
https://www.onsemi.com/pdf/datasheet/fdms86101dc-d.pdf)
It seems that it can meet my needs, but there is a data in the datasheet Id = Drain Current − Continuous TA = 25°C Ratings=14.5A. This data makes me very confused. Doesn't it mean 100V, 60A? Why does 14.5A appear again? Can this product meet my needs?
