I have a semi home built, semi commercial valved RF amplifier and low voltage supply for it that on initial turn on will often trip the house main distribution panel ring main RCD. After it's been on for a bit (say a few minutes, maybe less, not really tried that yet), it will turn off and on again OK for maybe the rest of the day. The HV supply is a serious bit of kit, but not involved at all as it's in a separate cabinet and not plugged into the mains or the RF section. My "shack" is upstairs and the wife is getting Royally fed up with me tripping the RCD and the TV etcetera going off whilst I try and diagnose. When I reset the main RCD all the outside security lights turn on, the cooker clock needs re-setting, blah blah. A real PITA!
The equipment has a soft start for the (big) heater transformer, and a 240 to 110 volt dropper transformer for a cabinet fan, plus a 240V centrifugal blower. It's pretty simple really, but I am unable, so far to determine why it does this. Once powered up it run for hours. I have tried an MOV across live and neutral. Our UK mains is similar to that in Oz, but not like the USA. We have live and neutral, and earth. Earth and neutral are bonded together at the local sub stations I believe. The supply is 50Hz.
Can I try and find the cause with it isolated form the mains? How? Is there a way to feed it from the mains without tripping the RCD? I have a 1 to 1 isolation transformer, but not sure it will handle the current draw very happily. The fact it powers up OK once it has initially tripped the RCD a couple of times suggests a capacitor issue to me?
Thanks.
