think an advantage analog oscilloscope is for waveform with sweep I remember is nice to view it, I had a Tektronix 2247a, with 1 ms sweep rate the visualization is nice, if compared sweep waveform even with MDO3054 is better in analog oscilloscope, AM signals looks similar even in my low cost siglent with SPO tecnology. Finally I sold that scope for is big an heavy, measurements and cursors have poor accuracy.
I have Tek MDO3054, TDS3012B agilent dsox2002a, siglent 1104x-e, GW GDS2202E all with DPO SPO or every name that's means Phosphor emulation, Also I have Scopemeter Fluke, this scope is not has phosphor emulation therefore waveform visualizaion is bad compared with analog scope.
Maybe low cost DSO and analog was a good combination when phosphor emulation was very expensive, but visualization performance for example in siglent 1104x-e is so good like TDS3012B, I think analog scope can works for comparing repetitives waveforms with DSO, non repetitive waveforms in analog oscilloscope is imposible, display is little compared with moderns DSO, is extremely limited on functions and triggers, I want an Iwatsu 7811 or lecroy 302 only for this propuse, but big size is limitation because takes same space a power supply and bench multimeter or waveform generator, are very noising, probe attenuation is other problem, only 10 or 100x with readout pin, arbitrary attenuation is imposible, active probing? imposible, some high frequency signals must be analized with active probe, pasive probe change drastically its impedance with high frequency even inside bandwidth.
Single shot function is impresindible for diagnostic or other specialized function, I only work in repair industrial and agriculture electronics, capturing for my is essencial, but all people has different needs, I think analog scope can be only optional, if space is not a problem, if you can buy a scope for a good price in work conditions can be good buy. up to 200 usd maybe 250 usd good price, near to 400 USD can you get a SDS1104X-E.
