Author Topic: NO Problem ANYMORE with Full Wave rectifier using TL082CP. UPDATED on July 11th  (Read 1663 times)
Offline NHSA
  • Country: mx
Newbie here and having a problem with a full wave rectifier circuit using the Op Amp TL082CP.
Have set up the followong circuit using 10K and 5K resistors instead of the 6K8 and 3K4 resistors but guess this does not matter.
My problem is that the negative wave is rectified half of the Positive wave. Have tried during the last 3 days to get it even by changing the resitor values. Have read about how the inverting amplifier calculates gain but no result ...
[attach=1]
Below a screenshot of the result measured in my oscilloscope. Before the full wave rectifier I have a non inverting amplifier.
[attach=2]
Thanks for any tips and regards Rainer
« Last Edit: July 11, 2021, 09:07:03 pm by NHSA »
Offline Andy Watson
Re: Problem with Full Wave rectifier using TL082CP
« Reply #1 on: July 01, 2021, 07:25:23 pm »
What power supply voltages are you using ?
Offline Zero999
  • 0999
« Reply #2 on: July 01, 2021, 07:41:22 pm »
Are you using a single supply i.e. 0V for negative and +12V?
It looks like phase inversion, due to the common mode range being exceeded.
The schematic shows the LM358, so why are you using the TL082?
The TL082 won't work properly, if its inputs go within a couple of volts near its negative rail. The LM358 will work all the way down to 0V.
Offline NHSA
  • Country: mx
« Reply #3 on: July 01, 2021, 08:28:14 pm »
I am using +-7,4 Volts
Rainer
Offline NHSA
  • Country: mx
« Reply #4 on: July 01, 2021, 08:29:38 pm »
Thanks. Will do the same test with some LM358.
I am using TL082 because I ahve plenty of them
Rainer
Offline magic
« Reply #5 on: July 01, 2021, 09:17:01 pm »
Output should be same amplitude as input so where is the 40x gain coming from? :-//
Check waveforms at Vin and P2.
Offline NHSA
  • Country: mx
« Reply #6 on: July 01, 2021, 09:38:24 pm »
The signal comes from a non inverting amplifier with its output delivering the 100X gain to the input.
I wrote in my original message " Before the full wave rectifier I have a non inverting amplifier. "
Will check the points you told me.
Rainer
Offline NHSA
  • Country: mx
« Reply #7 on: July 01, 2021, 11:04:02 pm »
Hi Magic,
Looks like my preamplifier is doing something strange. Measuring the output of the pre-amplifier the curve is nice AC with same +- values.
There is a Voltage difference but I guess it comes from the values from R5 divided by R3. The values are R5 = ~10 and R3 = ~4K7. After writing that, I changed R3 for two 10K in parallel and now I have exactly bot curves equal on the rectifier. Thanks.
Rectifier with no input from my pre-amplifier at 100X is doing fine. See attached images
Now I need to find out why my output from the pre-amplifier when fed into the rectifier, the rectifier delivers half the voltage for the positive input and correct voltage for the for the negative output ¿? No idea where to start. The pre-amplifier is also a TL082 working as a non inverting amplifier.
Rainer
« Last Edit: July 01, 2021, 11:29:25 pm by NHSA »
Offline NHSA
  • Country: mx
« Reply #8 on: July 02, 2021, 05:16:46 pm »
I guess I did not explain clearly my problem.
Non inverting amplifier, TL082, works OK creating a nice symmetric curve. I am feeding a Sine curve into the positive pin and amplifying 80X.
Violet line is input from AWG, 50 mV, and Yellow line is output at Pin 1, 4 V.
[attach=1]
Full wave rectifier, TL082, is working OK. Feeding in a sine curve from my AWG it gets rectified correctly, e.g. negative portion is inverted correctly and has same voltage as positive portion.
[attach=2]
Now when I connect the output of my non inverting amplifier, attach1, to the input of the full wave rectifier, attach2, then the negative portion is only inverted at half its value, e.g. 2 V instead of 4 V and that is my problem. I am clueless. What is different when feeding a sine curve from the output of my amplifier to a sine wave fed by my AWG ? I am using two TL082. One as amplifier and from there I go into the next one.
The Pins 5, 6 and 7 of the first TL082 are not connected to anywhere. Does that matter ? Both TL082 get power from the same source.
[attach=3]
Here again the fullwave rectifier circuit
[attach=4]
Thanks for any tips.
Rainer
Offline NHSA
  • Country: mx
« Reply #9 on: July 02, 2021, 07:38:14 pm »
[attach=1]
[attach=2]
[attach=3]
[attach=4]
Rainer
Just to be sure I did set up the whole enchilada with two LM358 instead of the two TL082 and I get the same result except the positive is now half the voltage  |O
Have a nice weekend
Rainer
Offline Andy Watson
« Reply #10 on: July 02, 2021, 09:52:30 pm »
Pull-out the data sheets for the op-amps that you are using.
Op-amps require a certain voltage "headroom" in order to operate correctly. To operate correctly, the inputs to the op-amp need to be within a range of voltage - sometimes  called "common mode range" in the data sheets. Similarly, the output can only function within a defined range. However, extracting this information from the datasheets often requires interpretation (and guess-work) as to what the manufacturer is implying.
From memory, the TL08x series require approximately 2V headroom (on both power supplies) to operate to their full specification. You are trying to push a 5V signal with only 7.4V power supply - you are already sailing very close to the edge of the op-amp's operating range ... and we've not allowed for the 0.6-0.7V lost in the diodes in rectifier circuit.
I believe the LM358 claims to operate down to its negative supply, however, it has similar limitations with respect to the positive parts of the signal.
Offline magic
« Reply #11 on: July 02, 2021, 10:02:19 pm »
Input common mode is at ground so that shouldn't be a problem. Output could be, but with 4V signal the outputs shouldn't swing more than ±5V and that seems OK on a ±7.4V supply. Nevertheless, the fact that TL082 and LM358 behave differently suggests that something may be amiss.
But I don't know what's wrong. I would try:
1. get more amplitude from the AWG and see if there is a particular level when things get weird
1b. if not possible, reduce gain of the preamp
2. simultaneously scope the output of the preamp and of the rectifier, see which of them misbehaves
Offline NHSA
  • Country: mx
« Reply #12 on: July 02, 2021, 11:40:24 pm »
Hi Andy,
Thanks. I just cranked the supply voltage up to +-15V and it remains the same. Amplification of voltage output max +- 5V. So there was headroom of -+ 10V.
Rainer
Offline Zero999
  • 0999
« Reply #13 on: July 03, 2021, 09:23:09 am »
That might be your problem. Op-amps can do funny things, if their inputs are not connected to anything, so it's important to correctly connect unused op-amps, otherwise they can affect other amplifiers, on the IC. Connect pins 6 & 7 together, to make a unity gain amplifier and connect pin 5, its input, to 0V.
The following users thanked this post: NHSA
Offline NHSA
  • Country: mx
« Reply #14 on: July 03, 2021, 05:06:46 pm »
Hi Zero999,
Thanks for that and yes that is why I asked. From a former test many years ago, ~ 6 years, I somwhow knew it is not good to leave them unconnected. Sorry, I could have been less lazy and do a search   :-+
Yesterday I wired the unused OpAmp as a voltage follower and still the same problem.
Today after reading your answer I wired the pins 5, 6 and 7 as you recommended and still the same.
I even changed both TL082 by two new ones and still the same assymetric rectified full wave.
Amplifier works OK alone and rectifier works OK alone e.g. not connecting the Amplifier output to the rectifier input.
I will keep investigating this. Next step is to set up the same enchilada using a LMC6484.
Have a nice weekend
Rainer
Offline Andy Watson
« Reply #15 on: July 03, 2021, 05:40:13 pm »
Curious!
Can you confirm that you are using two power supplies and not one power supply with voltage splitter to derive the 0V?
Offline NHSA
  • Country: mx
« Reply #16 on: July 03, 2021, 06:36:08 pm »
Hi Andy,
I am using a Korad KA3305P power supply for the voltage supply.
I am not using a voltage splitter from one battery.
I can test the result using two batteries and see what comes out then.
The negative output of channel 1 is connected to the positive output of channel 2 via a jumper lead. From here I take 0V or ground. Channel 1 delivers the + 7.4V and channel2 delivers -7.4V to my circuit.
Just measured it and I get exactly 7.4 volts from each output measured against the middle contact e.g. 0V or ground.
I have searched Internet and learned from there how to get the positive/negative supply.
Thanks Rainer
Offline NHSA
  • Country: mx
« Reply #17 on: July 03, 2021, 07:00:03 pm »
I found another curious thing.
The difference between negative and positive rectified wave is always ~ 1V.
Do I have in the full wave rectifier a problem of an amplifying the positive / negative wave and that gives me the difference ? Could that be due to the tolerance of the resistor values ?  :-//
Yellow curve is amplifier output and violet curve is rectifier output.
Will check it changing the resistors in the circuit.
Rainer
Offline Pulsepowerguy
« Reply #18 on: July 03, 2021, 08:31:04 pm »
You might find these videos helpful:
Offline magic
« Reply #19 on: July 03, 2021, 09:05:07 pm »
Build the complete circuit with the amplifier and the full wave rectifier.
Put one probe between the amplifier and the rectifier.
Put the second probe on the output of the rectifier.
What happens?
Offline Andy Watson
« Reply #20 on: July 03, 2021, 10:17:55 pm »
There is no reason you cannot operate this circuit at DC (... er, it is d.c. coupled throughout ... isn't it?) Make a resistive divider (or find another source) to supply the peak d.c. signal level to the input. Then follow the voltage levels through the circuit - you only need to test with +peak, 0V and -peak inputs and you should be able to determine where the offset is occurring with a voltmeter.
Possible, but unlikely. Also, you swapped that op-amps and problem shifted to the opposite polarity - this would suggest it is not a resistor tolerance problem.
Offline viperidae
« Reply #21 on: July 03, 2021, 10:31:53 pm »
Isn't the load seen at the input going to be different for each polarity? So you'd need a low impedance input to mitigate that.
Offline Andy Watson
« Reply #22 on: July 03, 2021, 10:53:22 pm »
If I've followed this thread correctly, I believe there is an intervening "buffer" amplifier between the input and the rectifier.
Offline NHSA
  • Country: mx
« Reply #23 on: July 04, 2021, 12:29:30 am »
What happens?
Hi magic,
The circuit is built complete and when all is connected and one probe is at the amplifier output = the wave is symmetric and so it goes into the rectifier. On the output of the rectifier the wave is assymetric by 1 V
Rainer
Offline NHSA
  • Country: mx
« Reply #24 on: July 04, 2021, 12:38:46 am »
The output of the amplifier is symmetric and that is what gets into the rectifier and out comes an assymetric rectified wave.
The output of the amplifier is -/+ 4.5 Volt and that goes into the rectifier.
The output of the rectifier is on the positive wave +5 V and the rectified negative wave is +4 V
Rainer
