It looks like you are not using any flux. That would be the first issue.
Then try to just use a sharpened toothpick and clear the hole using that. Melt the solder (add more solder, it will actually help), then quickly push the toothpick though the hole.
Also, the soldering on the first hole was not great to begin with. You really need flux.
