Well, first of all thanks to all of you.
I have done a phase of the squematic with the components that I have rally used. I´m attaching the file behind.
Apart from the notes that I take on the photo I would like to be recommended about this items.
1. The resistance that goes to the driver is 100 ohm but some of you told me that it isn´t the most apropiate value. Which value would you recommend me?
2.I tried some days ago this circuit modifying the value of the C13 capacitor. I just try the circuit with a program that putted 'HO' (HIGH or LOW) and 'LO' (HIGH/LOW). Well, I putted some capacitor with more value, 10 uf and 33uf for example. Firstly the voltage of the high side MOSFET in the gate was about 24 V more or less, but instantly decreased, the lower the value of the capacitor, the faster it fell the voltage on the gate. This can lead on what someone told me, the program really turns off the high side MOSFET but physcally it is really slowly decreasing his value instead of putting off instantly. This can lead into a short circuit between the two MOSFETs.
3. Which MOSFET would you recommend me? Do you think the ones that the guy told me are okay for what I´m trying to do?
4. He also mentioned something about the peak current when the motor tries to start spinning. I didn´t take that into account and the MOSFET that I had used wheren´t able to handle that so they burned.
Tell me what you think, thanks!
