I'm thinking of buying a PM3040 Neoden stencil printer and getting the 37x47 stencils from Seeedstudio. Neoden says that the printer comes with a 10cm squeezer; however we are planning on applying paste to a large panel. The effective area of the Seeedstudio 37x47 cm stencils is 19x29. Does this mean that we need a squeegee larger than 19cm? Is it possible to use a 10 cm squeegee and pass over sections of the panel instead?
Thank you very much for your time,
Savinda
