Author Topic: Sensors, probes, cables, etc, for oscilloscope for automotive diagnosis  (Read 3267 times)
Offline danbuffTopic starter
Hello all,
First off, thanks for a fantastic group of knowledgeable helpful folks.
So much to learn..
I am going to be buying a DSO for general electronics usage, but also automotive diagnosis.
Scope likely DS1054Z
Suggestions for probes, cables, sensors for the scope? Maybe home-brew..
I have a clamp on current probe..
Wondering what type of sensors/probes for auto diagnostics.. Secondary ignition, etc.
Also, place to purchase DS1054Z ?
Thanks so much!!
Dan
Retired, tinkerer, ham operator
Offline Andreas
Re: Sensors, probes, cables, etc, for oscilloscope for automotive diagnosis
« Reply #1 on: December 31, 2016, 07:17:39 pm »
Hello,
what about this:
https://www.picoauto.com/products
With best regards
Andreas
« Reply #2 on: December 31, 2016, 08:39:52 pm »
Thanks Andreas.. Those are the types...
Perhaps I can find some DIY versions too..
Gives me good ideas!!
Dan
« Reply #3 on: January 01, 2017, 12:13:25 am »
Here's a DIY example of a coil over plug sensor: http://www.ford-trucks.com/forums/1159255-poor-mans-cop-scope-probe.html
I know commercial ones are available, but might be fun to experiment with a roll your own..
Commercial one:
https://www.otctools.com/products/scope-universal-cop-probe
Dan
Offline Mickster
  • Country: bm
« Reply #4 on: January 01, 2017, 12:38:57 am »
The Pico First Look Sensor (Pressure transducer) is quite handy, albeit pricey. It is not a pressure sensor, it only measures changes in pressure, but this is useful for checking for low compression/leaky valves etc, without pulling spark plugs and carrying out a regular compression test. Attach it to a vacuum take-off on the intake manifold or stick it up the tail pipe, trigger off cylinder 1 and use the chart to line up the defective cylinder(s) to your trigger point.
A great place for automotive info is here:
http://www.autonerdz.com/cgi/yabb2/YaBB.pl
I have no affiliation with either Picotech, or Autonerdz.
Regards.
« Reply #5 on: January 01, 2017, 01:51:33 am »
Thanks for the link! I wasnt aware of that site.
I agree, Pico pressure transducer is fine piece.. But pricey for non-professional need.
I am finding youtube videos on DIY pressure transducers for scope usage.. Cool stuff.
Dan
« Reply #6 on: January 01, 2017, 05:52:18 pm »
Pressure pulse sensor would be another item to use.
Here is a link to a DIY unit: http://www.locostbuilders.co.uk/forum/47/viewthread.php?tid=200739
commercial version:
http://autoditex.com/pressure-pulse-sensor-63.html
Dan
