Author Topic: looking for a connector  (Read 1459 times)
Offline ealexTopic starter
« on: December 08, 2016, 10:09:05 am »
Hello
I'm trying to find a female connector similar to the tall ones used in this photo:
the entire page link is : http://www.nixieclock.org/?p=411
I could only find something like this: http://www.mouser.com/ds/2/418/NG_CD_66504_AP-691769.pdf
the one i found has a crimp-able end, instead of a solder pin.
i could crimp it over a 0.5 - 1mm wire then solder that wire in, or i could just crimp it with no wire and use the crimped end as a  solder terminal.
any other hints on what to look for ?  the tube's pin is 1mm in diameter and i need at least a height of 11-12mm to clear the tube's end
Offline dmills
Re: looking for a connector
« Reply #1 on: December 08, 2016, 10:26:36 am »
Looks like the sort of thing mill-max specialise in?
https://www.mill-max.com/product_finder/1
Of course the mill-max stuff is expensive so it is probably a cheaper version, but if you only need small quantities....
Regards, Dan.
Offline klunkerbus
  • Electrical Engineer (retired early)
« Reply #2 on: December 08, 2016, 12:55:44 pm »
Searching on "tube socket pins" brings up some possibilities to look at.  At least looking through the image search results.
« Last Edit: December 08, 2016, 01:07:47 pm by klunkerbus »
« Reply #3 on: December 08, 2016, 03:50:14 pm »
