Author Topic: PCB Drill Press and Fence?  (Read 27508 times)
Offline Spawn
  • ³²µ º'ºººº³²
Re: PCB Drill Press and Fence?
« Reply #25 on: April 10, 2013, 04:32:18 am »
You can drill nicely without any modifications after some practice, however you can use a small LED in the hole where the drill goes and that lights up the PCB from below and you can see better where you have to drill, just lower the top part of the Proxxon till the drill almost touches the PCB and that makes easier to drill and get the PCB in right position.
About the bits, I won’t be much help I guess because I am using second hand carbide bits which are sharpen I get them here in the Netherlands.
http://www.bungard.nl/index.php?option=com_virtuemart&page=shop.browse&category_id=12&Itemid=1
Offline iamnothimTopic starter
  • Hello
« Reply #26 on: April 10, 2013, 04:36:34 am »
Perfect...
Netherlands.....
Forget the drill bits.
Please.... find me a nice set of E188CC's to buy.    La Radiotechnique preferred, but Philips / Amperex, Heerlen plant will do. ;D
Warning, This post is litered with mispellings and improper frammer.
Offline Spawn
  • ³²µ º'ºººº³²
« Reply #27 on: April 10, 2013, 04:46:11 am »
LOL  ;D I am not much in to tubes, only one I could find on a local auction site was this and it is not a Philips:
http://link.marktplaats.nl/663041953
  • Hello
« Reply #28 on: April 10, 2013, 04:47:01 am »
I had to ask....
I have a valve sickness.
  • Hello
« Reply #29 on: April 10, 2013, 04:54:46 am »
I Like The Netherlands...
Both from Heerlen...
http://www.adufus.com/wp-content/uploads/2013/04/RTC-1-21.jpg
http://www.adufus.com/wp-content/uploads/2013/04/RTC-1.jpg
I appreciated the Proxxon photos you posted.  That helped and I'm headed to your Youtube channel.
I will officially close this thread.
Thanks
Offline peps1
  • if you can't open it, you don't own it!
« Reply #30 on: April 10, 2013, 11:11:47 am »
 I use a dremel freehand with carbide bits, and have done thousands of boards that way.
The dremel press is totally useless, and I switch it out for a Silverline budget drill press that works a charm....but still prefer doing my PCB drilling freehand.
  • Hello
« Reply #31 on: April 10, 2013, 04:53:45 pm »
My hands have tremors, so freehand is out.  It would look like graffiti.
I need a rock solid press.
I do appreciate your post and recommendation.
