Author Topic: Electric consuption for triphase dryer conveyor(with electric meter)  (Read 602 times)
Offline tlhsglmTopic starter
Hi dear friends,
My friend's father have a dryer like below youtube video(video is not mine) . I will open it and put insulating materials. But i want to see how much it will effect electric consumption.
Machine first heating up for half hours and then we are putting textiles to dry. i want to see electric consumption for like 6 hours. Because -as you know- motor is keeps running but heaters not open or at same power for everytime, i have to see consumption for a while.
I have done lot of arduino projects and some monophaze projects but none triphaze so i want to do it right and safe.
Kindly can you please help on below?
I want to see how much electricty this machine consumpts in 1 day. I have uni-t ut89x multimeter but im not sure how much amps machine consumps. and since i want to see it's one day consumption i had and idea that i pictured below;
Can electric meter mislead me? What do you think about my solution?
https://www.photobox.co.uk/my/photo/full?photo_id=504499003076
« Last Edit: January 27, 2022, 05:30:33 pm by tlhsglm »
Re: Electric consuption for triphase dryer conveyor(with electric meter)
« Reply #1 on: January 27, 2022, 09:47:14 pm »
please
Offline Ground_Loop
« Reply #2 on: January 28, 2022, 03:47:34 pm »
I would recommend you use a proper power logger.  Fluke 1748 for example.  They are widely available for rent.
There's no point getting old if you don't have stories.
The following users thanked this post: tlhsglm
Offline Siwastaja
« Reply #3 on: January 28, 2022, 04:14:14 pm »
Or just a normal electricity meter (energy meter). Available everywhere. Intended for billing, accurate within a few %. Cost for a 3-phase model is something around $100, though. Maybe you could find a used unit, even an old mechanical.
If you want actual logging, these have at least a blinking LED you can optically couple to, and many have open collector optoisolated pulse output for easy interfacing with any logging system. One pulse per Wh or similar.
« Reply #4 on: January 28, 2022, 05:16:22 pm »
thanks, my paint file at first message includes three phase billing energy meter i will use it
Offline Siwastaja
« Reply #5 on: January 28, 2022, 06:11:21 pm »
The link does not work and "photobox.co.uk" has broken server configuration not returning 404/403/whatever the error is, but instead silently redirecting to front page.
