Author Topic: Triac for touch lamp  (Read 3894 times)
Offline maliumTopic starter
« on: October 03, 2013, 12:46:53 pm »
Hello, me again :)
Quick one, I have the:
http://www.nxp.com/documents/data_sheet/MAC97A8_A6.pdf
MAC97A6 (08h) in the touch lamp gone under. As this can not be bought here, can somebody please see if I could use BT137-600E instead or even better, some of below:
http://www.nxp.com/documents/data_sheet/BT137-600E.pdf
http://pdf.datasheetcatalog.com/datasheets/151/323032_DS.pdf
http://www.bourns.com/pdfs/tic226.pdf
http://pdf1.alldatasheet.com/datasheet-pdf/view/20139/POINN/TIC226D.html
http://pdf1.alldatasheet.com/datasheet-pdf/view/22031/STMICROELECTRONICS/BTA08-600B.html
This are all available.
Also, I noted that pins on the MAC are positioned different than on the others, can than the alternative be used?
Many thanks!
Offline David_AVD
Re: Triac for touch lamp
« Reply #1 on: October 03, 2013, 09:04:09 pm »
The original TRIAC is a sensitive gate type and works in all four quadrants.  Best bet is to make sure the replacement one has these features as well.  You still need a suitable voltage and current of course.
Offline Paul Price
« Reply #2 on: October 04, 2013, 01:38:00 am »
BT137 would work well as robust replacement, just get remember the pinout is different, so put it in the right way.
« Last Edit: October 04, 2013, 01:37:28 pm by Paul Price »
