Hi everyone,
I have an unusual, and perhaps foolish, project I'm working on, as an absolute beginner. What I'm attempting to do is modify a yard-sale record turntable to extend the range of its pitch control from +/- 20% (give or take) total speed to (as close as possible) to 0-100%, so that I can slow down and stretch samples continuously for a music composition so that I can do it in real time and "play" the sample pitch/speed like an instrument. I'm aware that modern turntables offer this feature, and that they use micro controllers to do so, but the price point for a Technics SL1200, for example, is rather steep.
Someone on reddit told me that I probably couldn't do this closed-loop, but I digress. Here's what I've learned so far:
Here's the schematic and wiring diagram as provided by the manufacturer. This appears to be for a European or Asian version, but it's the same model, a Sanyo TP-B2:
The first thing I tried was to put a higher resistance pot in place of the pitch wheel, which made it go faster. Ok. Next step. I realize that the motor uses something like a servo to control wow and flutter. Then, I quickly discover that neither does this schematic describe the servo motor control, nor does there exist an easily available diagram online. Well, here's the label on the back, anyway, in case someone is a schematic-finding expert:
I can't find anything at all, so I crack it open and try to make my own schematic. Here's the top of the board with the space between the traces indicated in black:
And here's the schematic I drew:
This schematic represents everything inside of the area indicated as "Motor" on the factory schematic, with the pitch wheel and 33/45 rpm selector represented by a variable resistor in my diagram.
Shamefully, I do not own a transistor testing device, so I can't confirm anything, but I did note the part numbers for them and managed to find the data sheets online.
After studying this for a while, I come to the (perhaps wrong?) conclusion that they're set up as common emitter amplifiers, and they're configured to cancel each other out to keep the speed from fluctuating at all, which seems very important for audio playback.
I also took an oscilloscope reading the base of C2298 to ground, I think. Sorry for the vagueness here, I did it quite a while ago. To me this looks like the motor is correcting its speed by trying to cancel out the amplified signal from 2SD603.
And that's where I'm stumped. Or maybe defeated. Is there any way to do what I'm attempting without just handing over speed control to a micro controller or something? Is
that even possible?
Although I do have an end goal here, which is a cheap turntable that has continuous speed control from (close to) 0 rpm to 33pm, approximately, I'm also a curious neophyte and would appreciate any enlightenment on how this stuff works, or what I should investigate next.
Thank you for reading.
