I'm looking forward to Skylake-EP, the new platform purley, and its improvements.
There are already top of the line chips leaked out for LGA3467 platform as well as mobos from SuperMicro on Taobao.
The top of the line chip is 32-core, 2.1GHz E5-2699v5, which has a 220W TDP.
The currently revealed E5v5 has 28 cores at 1.8GHz, but the new unreleased beast will have 32 cores at 2.1GHz.
Even though, 220W TDP makes it not anywhere more advanced compared to v4 platform -- 220W/32/2.1GHz=3.27W/GHz per core, and current flagship E5v4 has 145W TDP, which corresponds to 145W/22/2.2GHz=3.00W/GHz.
Also, it is unknown what will be all-core turbo boost frequency of the new chip, while the v4 generation can turbo boost up to 2.8GHz when all cores are crunching numbers.
I'm also hoping that it may allow people to get dual socket motherboards,
WITHOUT needing to get hold of special (often server only), special "NUMA" aware software. Which can properly exploit dual socket cpu systems, as regards memory. I have not seen details yet, showing to what extent Intel have achieved this. There will probably still be a need/improvement, by using special software (NUMA etc).
It is perfectly possible Intel show little or no improvement in this respect. I just don't know yet.
Because (as you said in an earlier post), the existing two socket motherboards, have relatively slow inter-memory (QPI) links between them. Making NUMA aware/capable software somewhat important, if you want to get the best performance out of it.
Hopefully the new platform (Purley) will have much better/faster memory links between the two cpu sockets.
If not, a maximum of 32 cpu cores (probably more later, on the new/fresh platform), even on a single socket. Does not sound too bad.
The next one will be rather "future proof", because it will take (the motherboard), at least two or more generations of Intel server chips. I.e. will remain current for probably 5 or more years (NOT guaranteed), for the new socket type.
Whereas the existing/current one (the OP seems to want to get), has probably seen the last new Intel cpu, it is ever going to get, and will gradually disappear completely, once the new ones come out. But it will be still supported, for some time.
