I know, more dumb questions, Im happy I found all of you.
On my first little power supply i had used such a small transformer I mounted it directly on a raised circuit board with nylon stand offs, so it was in no way touching the enclosure. However, my question is, when mounting larger (Foot Mount) type transformers, can the foot be mounted directly to the bottom of the metal enclosure or does it needed to be suspended above the metal enclosure to prevent any contact?
