So i'm trying to design an ultrasonic transceiver... I want to use a H bridge made from a few transistors to double the voltage across the transducer( this is R7 in my schematic since i couldn't find a good spice model for the transducer). The power supply voltage is 12V. My signal source has a 5V square wave at 40 kHz. I have already tried different configurations but i always encounter the same problem: So with a 5V input signal. My H bridge goes from 6v to -12V. As soon as i have a 5,5V input square wave the H bridge goes from 12V to -12V, this is what i want to achieve. I could use an extra transistor to generate a 12V square wave from the 5V square wave. But i don't understand why the circuit only functions as expected with a 5,5V signal and not with a 5V signal? I can't find the error, any suggestions?
