Did you find the documens linked below?https://www.ti.com/lit/pdf/swra372&usg=AOvVaw07hrK5qhcqPR5RBU0xUJp7http://ww1.microchip.com/downloads/en/appnotes/00826a.pdfIf you want to be pedantic about getting the right value, it's possible to calculated it.The MCU input pin and parasitic crystal capacitances can be found on the data sheets. It's also possible to calculate the parrasitic, but as mentioned above, an approximate value is good enough for most applications.
