I'm looking at linear regulators to step down a voltage from a switching regulator to a fixed voltage (i.e., turn 8-10 volts into 5 volts). I'm a bit confused about the PSRR. My switching regulator (LM2679 and LM2673) operate at 260 kHz. Most of the linear regulators I've seen have a PSRR at 60 dB at 120 Hz. That figure drops as the frequency increases. So, for example, most data sheets I've seen reach ~35 dB at 200 kHz range. At that level, assuming the formula: dB = 20 * log10(Vin/Vout), the ratio between Vin/Vout for ripple would be 56x; if I'm understanding it right, the regulator would reduce the ripple by 56x (comparing the output ripple to input ripple)? Is that value good considering my input frequency?
