Author Topic: PSU - getting +12, -12 and 0 volts  (Read 347 times)
Offline level6
« on: February 22, 2019, 07:33:12 am »
I just purchased a Siglent SPD3303X-E bench power supply. It has three outputs, one of them being a range of fixed voltages, the other two being fully adjustable.
What I need is to be able to get +12, -12 and 0 volts from the unit. Would I do this by setting the outputs to independent mode, set both to 12 volts, then combining the inner + and - terminals to get my zero volt, using the remaining terminals for the + and - voltages?
The following users thanked this post: Moriambar
Offline MarkF
Offline jeroen79
Re: PSU - getting +12, -12 and 0 volts
« Reply #2 on: February 22, 2019, 08:42:25 am »
Going by the datasheet it supports independent, series and parallel modes.
Series mode is what you're looking for.
Offline level6
« Reply #3 on: February 22, 2019, 08:48:42 am »
So serial mode and combine the remaining terminals as the zero reference?
Offline Moriambar
« Reply #4 on: February 22, 2019, 09:37:15 am »
let me add to this question: what would it happen if I were to short the + of one channel to the - of another channel (both active) in idependent mode?
Cheers
Offline level6
« Reply #5 on: February 22, 2019, 12:28:13 pm »
I figured it out. Set to serial mode. The remaining terminals are zero volt. You can test by checking the voltage, should be 1/2 the output between the outer + or - terminals and any of the center ones.
