Author Topic: PSU wiring dilemma...  (Read 1162 times)
Offline LektroiDTopic starter
  • If it didn't explode, I'm happy.
    • Music here
« on: June 25, 2018, 02:56:17 pm »
Hi, I just did a continuity check on my switching PSU but the ‘COM’ which I presumed to be common ground are not connected to each other and also isolated from the chassis of the PSU, I’m wondering if I should tie all the COM connections and the chassis to mains ground (is it safe to do so)?
Offline bob225
Re: PSU wiring dilemma...
« Reply #1 on: June 25, 2018, 03:05:22 pm »
standard switch mode ? all the outputs are isolated and not reference on the dc-dc transformer - don't tie it to ground, and you don't really want it referenced to earth or the mains, that sort of defeats the filtering
    • Music here
« Reply #2 on: June 25, 2018, 03:20:30 pm »
Yes, switch mode...
So I'm guessing this is unusable for my purposes, as my power bus needs a common ground for all voltages... The +5V will not work from the COM of the +/-12V
Offline stj
« Reply #3 on: June 25, 2018, 03:46:38 pm »
you can tie the outputs if you need to i imagine.
nice selection of voltages, where did you get it and what's the output ratings?
    • Music here
« Reply #4 on: June 25, 2018, 04:32:06 pm »
It didn't explode, so all good.
One of AliExpress' finest, although I cannot find that particular one now...
Specs:
+5V 5A
+24V 1A
+/-12V 1A
Offline bob225
« Reply #5 on: June 25, 2018, 05:54:37 pm »
it looks like one of the meanwell clones
Offline stj
« Reply #6 on: June 26, 2018, 10:41:36 am »
not good enough for me,
i was hoping for 24v at 3A+ and 5v at 8A+
