Author Topic: PTH test pins?  (Read 994 times)
Offline electrolust
PTH test pins?
« on: September 28, 2016, 10:59:08 am »
I'm looking for test pins to put into a PTH.  .030" dia .1" pitch.  I found kinky pins and
http://www.newark.com/oxley/028-30p-la-kp2-silver/terminal-kinky-pin-pcb/dp/11N6258?CMP=AFC-OP
but I can only find suppliers in the UK.  Is there another vendor of this style test pin, with US availability?  Keystone doesn't make anything this small AFAICT.
Offline T3sl4co1l
    • Seven Transistor Labs
Re: PTH test pins?
« Reply #1 on: September 28, 2016, 11:10:20 am »
So a 5001 (et al) is off the table?
http://www.newark.com/keystone/5001/test-point-pcb-through-hole/dp/62W5135
Says 0.1" o.d., so they should stack (a little bit tightly) at that pitch.  The hole will be a tight fit, but it looks doable..?
Afraid I don't browse test points in detail, so I don't have anything to add that you probably haven't already seen or thought about before, anyway...
Seven Transistor Labs, LLC
Avid Rabid Hobbyist
Offline Pack34
Re: PTH test pins?
« Reply #3 on: September 29, 2016, 07:19:04 am »
