I agree with Langwadt and DavidAlfa. The controller uses the three hall sensor signals to generate the timing for the phase sequence driving the coil wires. If you halved the pulse rate from each sensor the phase sequence frequency would also be halved, and would no longer be synchronous to the rotor, resulting in rapid deceleration of the motor if its spinning or failure to start if not. Also most controllers would detect a sensor fault and error out.
The *ONLY* option that could achieve more speed from your existing controller would be if its firmware can be reconfigured to increase the controller's max. RPM limit and remap its throttle response. Even if you have the controller's configuration utility, this is unlikely to be possible for a factor of two speed increase if the firmware is closed source.
