Thank you all for reply.
Hero999 given solution have an op-amp. Inherently op-amp input impedance is high because of that it is suitable to get high resistance preamp output. And also it is in negative feedback loop in buffer amp stage because of that it boosts the impedance. My target understands the basic transistor design concepts; therefor I wish to use common collector amp (emitter follower circuit) method for increase input impedance. And also add a negative emitter feedback bias circuit to provide additional gain total output. I believe these methods are equal to single op-amp method. I have attached my circuit and results.
BrianHG, you say adding 100uf cap across the 2 bases of the complimentary pair, any way previously I have used Darlington pair method not the Sziklai Pair (I think you are telling about it) or I am not understanding you told thing where to put 100uf cap, if it is could you tell it with diagram please. As you told way I add small resistors to emitter output to prevent thermal runaway.
Anyone could you tell me how to calculate R11 feedback resistor value, I choose it just trial & error method I need to know how calculate it (I cal value is equaling to 5K)
