Author Topic: Purpose of isolation transformers  (Read 10046 times)
Offline SteveThackery
  • 50 year novice
Re: Purpose of isolation transformers
« Reply #25 on: October 09, 2024, 03:54:29 pm »
..... on the electronics bench the isolation transformer isn't really a safety tool. It solves a certain technical problem.
I very much agree with this analysis. Thinking of the transformer as a safety aid can imply that it improves safety, whereas in reality it turns one type of safety hazard into another type. It is an indispensable tool for a specific technical problem.
Offline johansen
« Reply #26 on: October 09, 2024, 04:49:58 pm »
What is the point of isolation transformers?
They exist these days, to argue about how lethal they aren't.
I cut the ground pin off my rigol oscope.
I also cut the ground pin on my hakko soldering iron, and I installed a neon lamp and resistor, so when I'm soldering on live equipment (accidently i swear) the light will illuminate.
Offline jonpaul
  • Analog, magnetics, Pwr high voltage, Audio, Cinema
    • IEEE Spectrum
« Reply #27 on: October 10, 2024, 05:57:23 am »
Was  EE and power supply consultant since 1970s, always used this setup.
120 or 240 Mains>>2 KVA Signal isolation 240:240>>10A GenRad Variac>>DUT.
All my Scopes are always used with normal grounded IEC 3 wire to mains.
Never had any issues.
Jon
The Internet Dinosaur..
passionate about analog electronics since 1950s
Offline Ice-Tea
    • Freelance Hardware Engineer
« Reply #28 on: October 10, 2024, 06:43:04 am »
Might I suggest you be carefull with throwing around remarks like that, even more so in the beginner section?
