I'm quite into induction heaters since a few weeks so I of course wanted to build a simple induction heater. But I didn't want to cheaply pick a schematic from the internet, so I tried to design my own. I'm here to ask if my schematic (Picture1) would actually do its job or if I can basically throw it in the garbage.
It's working behaviour is simply putting the work coil straight across supply voltage till the output voltage across the voltage divider is higher (caused by saturation of the inductor) than the forward voltage of the diode which activates the transistor and pulls the gate of T1 to ground and the gate of T2 to supply voltage. This discharges the capacitor and the cycle repeats.
I didn't bother calculating the component values because I don't even know if it works.
btw: I start to think that I don't even need T2 at all because the capacitor will discharge through the work coil if T1 is off.
What do you think about this schematic?
