This is probably a very dumb question, but I have a dashcam that is surprisingly power hungry (about 500 mA at 12V during parking mode) and I would like to install an additional battery for it to keep it running longer than it does on the car's own battery. I was thinking of installing one of those small AGM batteries (e.g. 9 Ah) in parallel with the car's own battery in the engine compartment, and this is the wiring scheme I had in mind. Is it okay to wire it this way? Mostly I am unsure about the diode I added to prevent the auxiliary battery from being used for cranking the engine (otherwise I would have to install quite thick cables for the auxiliary battery to accommodate the cranking current?). And of course, by installing the auxiliary battery in parallel with the car's main battery, I'm looking for it to be charged whenever the car is running and charging the main battery. Am I completely off here, or is this plan okay?
