Author Topic: putting good caps in paralell with bad.  (Read 567 times)
Offline METopic starter
« on: May 04, 2025, 02:24:22 am »
I have this dead stabilock SI4011 coms test set that fails a few self tests ,It has some smd electrolytic caps that measure almost open , ie>10 ohm esr ,can i tack new caps in paralell with the bad ones for testing , untill my new caps arrive?.
Offline CaptDon
  • Country: is
Re: putting good caps in paralell with bad.
« Reply #1 on: May 04, 2025, 03:09:44 am »
As a temporary test sure.
Offline Konkedout
« Reply #2 on: May 04, 2025, 03:22:06 am »
In general I think that electrolytic capacitors tend to fail open rather than short, so that is probably OK.
Offline PinheadBE
  • Pinball Freak
« Reply #3 on: May 04, 2025, 10:12:04 am »
Why bother ?
If you got new parts anyway, do no take any risks, and remove the old ones.
If those leak, you will have much more work to clean all the mess
Please keep our planet clean
