Looking for an official document or datasheet that shows exactly how USB 1.1 wants a DEVICE connector to be wired internally. I've read at least 5 different answers online:
1: Leave Shield Disconnected, it's already grounded at the host.
2: Connect Shield to Ground.
3. Connect Shield to Ground via 1M and 4.7nF RC.
4. Connect Shield to Ground via inductor/ferrite.
5. Connect Shield to Ground via 1M and many capacitors.
I've only found this document (
http://esd.cs.ucr.edu/webres/usb11.pdf ) and the only thing it says is:
6.8 USB Grounding
The shield must be terminated to the connector plug for completed assemblies. The shield and chassis
are bonded together. The user selected grounding scheme for USB devices and cables must be consistent
with accepted industry practices and regulatory agency standards for safety and EMI/ESD/RFI.
