Author Topic: PWM Converted Into 4-20ma (Vs) 1-5V Converted into 4-20ma  (Read 3704 times)
Offline ArduinoWannaBeTopic starter
« on: January 28, 2014, 08:20:02 am »
Hello Everyone,
Background:
I recently purchased a cheap relay board off of amazon, and the spec which I should have checked prior says it works off of 15ma-20ma signals. (Because a relay is ON-OFF) This doesn’t seem to make a lot of sense to me. Wouldn't be much easier to just make the board 0-5V or PWM much less work to switch a relay on or off that way I would think.
Anyways back to my real question. According to Ohms Law V=IR so a 250 Ohm resister minus the resistance in the circuit (Could be hard to measure the resistance in the circuit). That should give me my 4-20MA out, because this is just on/off I think this should work with a couple of resister sizes.
Secondly, I have seen people turning PWM into 4-20ma with a small R-C- Filter and then connecting to a Voltage-to-Current Converter like XTR110 which should work.
What is the correct way to do this?
This is just a demo setup so I think a crappy relay to save the wait time on component shipping is the way to go. When I build my final product I will not use 4-20 Output to a relay board.
Am I missing an easier solution?
Cheers
ArduinoWannaBe
Offline ivaylo
Re: PWM Converted Into 4-20ma (Vs) 1-5V Converted into 4-20ma
« Reply #1 on: January 28, 2014, 08:44:24 am »
A schematic of what you are trying to do would help, but I can't even tell if you understand what "4-20mA" means (and if your final product is not going to use why even mention it here)...
Offline Rerouter
« Reply #2 on: January 28, 2014, 09:00:43 am »
4-20mA is an industry standard signal, the purpose of that relay would be something like a high alarm (a sensor reading over ~75%)
as for driving it, if you have access to both ends, or even just the bottom end, then a single op amp current sink (look at daves dummy load) will fit the bill, even using that 250 ohm resistor as the measuring resistor if you want to keep the 1-5V signal logic
Just please search this site a bit, there are 20 odd threads showing the small tweaks that had to be done to make them stable (Dave oversimplified the schematic) which also include working component combinations,
« Last Edit: January 28, 2014, 09:09:47 am by Rerouter »
« Reply #3 on: February 02, 2014, 05:27:03 am »
Thanks Rerouter! :clap:
I will read the artical. Just looking for the best practice to make my prototype work well for testing.
Cheers
ArduinoWannaBe
