Author Topic: Potentially daft Supercapacitor related question, this is rated at 25V!  (Read 1052 times)
Offline bsodmikeTopic starter
  • Country: lk
Hi all,
I've got a 82mF Supercapacitor rated at 25V
https://export.farnell.com/kemet/als70a823df025/cap-82000-f-25v-alu-elec-screw/dp/2729143
Every article/video I can find on the subject, usually refers to an operational voltage of 2.5V; even the "Balance" chargers / Voltage safety PCBs on eBay are listed to work at 2.5Vdc.
My obvious assumptions about this supercapacitor:
  • Charge voltage should be ~90% of the max, so around 22.5VDC.  Can we charge at 25VDC?
  • Charging at around 0.5A to 1A should be safe?  Normally, the rule is not to exceed "1C" of a single cell, well at least for LiPos; a 1000mAh Lipo can be charged at 1A safely.  Does this apply here as well?
  • Minimum voltage: Unclear, thoughts?
Rough back of the paper calculations say 25V at 82mF can provide a max energy of 7.1mWh.  Given that a 9VDC battery has ~5.5Wh capacity, means this Supercapacitor can hold ~770 less energy? (Anyone able to double check these numbers?).
Thanks!
Cheers M.
Online wraper
  • Country: lv
Re: Potentially daft Supercapacitor related question, this is rated at 25V!
« Reply #1 on: November 28, 2021, 12:16:01 pm »
It's not a supercapacitor. Just a large aluminum electrolytic capacitor.
The following users thanked this post: bsodmike
Offline Gyro
« Reply #2 on: November 28, 2021, 12:39:09 pm »
The PDF datasheet is on that page too.
Best Regards, Chris
Offline rsjsouza
  • Eternally curious
    • Vbe - vídeo blog eletrônico
« Reply #3 on: November 28, 2021, 12:39:26 pm »
Indeed. The ones below are super capacitors, which usually start at many Farads, not micro or milli Farads.
https://www.newark.com/c/passive-components/capacitors/supercapacitors/prl/results
  • Country: lk
« Reply #4 on: November 28, 2021, 12:56:14 pm »
Oh nuts, sorry that was a normal cap for different project :palm:
Right here’s a Supercal 5F but rated at 12V. Does this mean it’s minimum voltage should not drop below 12V?
The data sheet does not mention minimum voltage limits.
https://export.farnell.com/kemet/fs1b505zf/cap-5f-12v-super-cap-radial/dp/2777893
Thanks!
Cheers M
Offline Gyro
« Reply #5 on: November 28, 2021, 01:05:50 pm »
Looking at the datasheet, that is a memory / low current standby capacitor. It has a 4 ohm internal resistance and charge / discharge currents in the mAs range - 18mA discharge is mentioned.
12V is the maximum voltage you can put across it. You treat it like a capacitor, not a battery, ie. it discharges to zero volts.
« Last Edit: November 28, 2021, 01:14:34 pm by Gyro »
Best Regards, Chris
  • Country: lk
« Reply #6 on: November 29, 2021, 06:48:00 am »
Aha that makes sense!!  Thanks  :popcorn:
