Zero999, I just wanted to thank you again for your help! I ended up running into an issue with the last circuit you provided. It worked great but wouldn't go below .25v. My uneducated guess is there was some load causing it not to be able to go to the low rail. None the less, I basically removed some parts and added some jumpers so that it (almost) matched the circuit you gave before the last one and it works 100% perfectly. Let me know if there is some way I can buy you a beer my friend!
