Author Topic: .  (Read 977 times)
Offline fullmoon6661Topic starter
« on: May 07, 2023, 11:48:23 pm »
« Last Edit: July 19, 2024, 07:33:10 pm by fullmoon6661 »
Offline jpanhalt
Re: QFN DFN Package PCB Layout Footprints
« Reply #1 on: May 08, 2023, 07:56:32 am »
It could be clearer.  See Capture1, which gives as Option 1 a pad the same width as the max.  Unfortunately, Renesas doesn't give guidelines for how to pick each option.  Capture2 clearly shows the pads wider.  Since two of the three recommend a wider pad, and the outlier (Renesas) gives wider as an option, that seems to be the way to go.  Maybe with the narrower pad one is expected to have a larger aperture in the solder mask (or no mask).
References:
Options (Capture1):
https://www.renesas.com/us/en/document/psc/20-qfn-package-outline-drawing-40-x-40-x-075-mm-body-050mm-pitch-ncg20
Pad wider (Capture2):
https://www.renesas.com/us/en/document/oth/qfn-mounting-manual
EDIT: It is frustrating dealing with the messy way images are handled here.  I intended to have Capture1 before Capture2.  Unfortunately, the first image uploaded created a huge blank space.  So, I uploaded Capture1 a second time.  It posted OK as the third image.  Then deleted the first, so now it's the second.  That's a real pain and requires multiple edits.
« Last Edit: May 08, 2023, 08:02:38 am by jpanhalt »
The following users thanked this post: fullmoon6661
Offline thm_w
  • Non-expert
« Reply #2 on: May 08, 2023, 10:20:04 pm »
For the outside pads, extending significantly from the QFN IC makes it easier to hand solder, hand rework and inspect the solder fillet, but reduces the board density. Its a trade off depending on what is more important to you.
The one thing thats considered superior though are the rounded pads from NXP, no reason not to use those.
