Author Topic: Why P-FET does no block reverse current  (Read 998 times)
Offline AlderelrobTopic starter
« on: July 07, 2023, 08:57:31 pm »
Hi all,
I am trying to understand why a P-FET is suitable for reverse polarity protection but not for reverse current blocking. See the attached image.
When we reverse the polarity of the input, the Gate-Source of the P-FET are tied together to the positive side. Vin becomes GND, and the FET remains open, with no current flowing through the FET or the body diode. Reason is Vgs=0V
However, if the input voltage is, for example, 10V, and the load is a motor that generates a back-EMF higher than Vin, how is it possible for the current to flow through the FET? the gate is always tied to the GND, the Source voltage vary making the Vgs always <0 so the PFET can conduct in both ways?
Thank you.
Online wraper
  • Country: lv
Re: Why P-FET does no block reverse current
« Reply #1 on: July 07, 2023, 09:01:17 pm »
Because as long as there is positive voltage on the output, FET will be in ON state. And in ON state it conducts current regardless of polarity. You need more complicated gate control circuit to block reverse current.
« Last Edit: July 07, 2023, 09:04:21 pm by wraper »
Offline langwadt
« Reply #2 on: July 07, 2023, 09:02:15 pm »
once the fet is on it conducts in both directions
Offline David Hess
  • DavidH
« Reply #3 on: July 08, 2023, 12:30:14 am »
Only the gate to source voltage matters for conduction in *either* direction.  When the MOSFET is on, it will happily conduct in both directions.
Offline DarkMode
« Reply #4 on: July 08, 2023, 02:41:27 am »
Does that you can use it as a Switch, regardless of direction?  :popcorn:
This one, a long time have I watched. All his life has he looked away, to the future to the horizon. Never his mind on where he was, what he was doing, HA! Adventure Ha, excitement Ha ... you are reckless - Yoda
Online xavier60
« Reply #5 on: July 08, 2023, 04:30:28 am »
No, because the MOSFET's intrinsic body diode will always conduct in one direction.
For both directions, 2 MOSFETs are needed or one MOSFET and a series diode.
I often see this arrangement in laptop computers, https://electronics.stackexchange.com/questions/617878/why-does-mosfet-n-back-to-back-switch-work
« Last Edit: July 08, 2023, 04:34:17 am by xavier60 »
HP 54645A dso, Fluke 87V dmm,  Agilent U8002A psu,  FY6600 function gen,  Brymen BM857S, HAKKO FM-204, New! HAKKO FX-971.
The following users thanked this post: I wanted a rude username
Offline David Hess
  • DavidH
« Reply #6 on: July 08, 2023, 08:17:13 am »
Exactly, a second MOSFET in anti-series is required to provide isolation from the body diodes.  If the sources are connected together, then the same bias supply can drive both gates in parallel as shown here:
https://www.bristolwatch.com/ele3/2c.htm
There are power MOSFETs which bring the substrate connection out isolating the body diode, however they are limited to lower currents and voltages:
https://www.microchip.com/en-us/product/MIC94030
