Hi sorin,
Are you sure about this comment? =>
but the original question is still unanswered I answered the question in the email conversation with
ElectronSurfBut of course I want to make you and the other readers happy too!
Current SourceThe reason for the power source is to remove the last bit of hum/noise from the design.
It was one of the last "tuning" steps I did to get the hum/noise a lot below the 5uV RMS at 20KHz bandwidth.
Of course the opamp noise also plays a part in this and of course the wiring technique you use, which becomes very dominant if you are not careful.
Wiring techniqueTwist the wires to and from the transformer, use a toroidal transformer, these almost always give the best results, exceptions aside.
Keep the transformer as far away from the other electronics as possible.
Twist the wires to and from the bridge cell, twist the wires to and from the buffer capacitor.
As best you can, make sure the wires around the Power Stage are as short as possible, wideband power transistors are used,
and it works best when the wiring inductances are as low as possible.
Some of the tips are a bit contradictory, it is also not easy to get the best out of test equipment.
Current Source-2Back to the current source, I chose this one around 6mA, which is 10x higher than minimum necessary for 5-Ampere output current.
I had applied a small selection to the indicated power transistors and arrived at a hFE > 30000.
But it in never good to assume the maximum of my selected transistors, so even with an hFE of 10000 of the Sziklay Pair, there is 12x more current available for achieving 5-Ampere output current.
I don't see the speed of the current source at 6mA as a problem with the capacities present in the node to which the current source is attached.
The datasheet of the LM334 shows that at 1mA the LM334 only needs about 25uSec to stay within 0.5% of the set value, at the large current I chose this gets a little better.
And as you yourself point out, the voltage variation is small, so slew rate problems will not occur here.
That HP never chose a current source to drive the Power Stage I can not say for sure, but I have studied many of their schematics.
Just because HP didn't do it doesn't mean that what I chose wouldn't be good.
I have therefore chosen to keep the noise level at this point as low as possible by using the LM334.
And yes, they are only small differences, but what do I care about the 0.5$ of the LM334.
This schematic was/is a test how well I could make it, far below the hum/noise level of commercial products.
And of course it is no problem for the operation to take a resistor instead of the LM334.
Some backgroundI design for myself, no one is standing here breathing down my neck whether it is ready yet or whether the parts chosen are too expensive.
I want quality for me and I want to learn to do it as well as I can.
On this and especially on the Dutch forum CircuitsOnline I show the path I take to achieve a good result, but also the mistakes and the assumptions that were not correct.
Also I don't see the schematic as Heathkit kit, this is because I know almost everyone wants to do it their own way and often ignore the decisions I chose after many hours of precision measurements.
Bram can I also use LM741, Bram can I use 2x a 2N3055, I hope you guys understand what I mean.
So I usually give a handful of tips on what to look out for and otherwise it's your journey to achieving good results.
I too have had to learn what it takes to make a good linear Power Supply!
One of my first ones I blew up at least five times due to a short circuit.
Another schematic I got from a friend of my father's when I was about 16 years old was more of an oscillator than a power supply.
Little did I know what phase and gain margin was.
Only at that time there was hardly anyone who could help me, in this day and age there are several Fora where very many people are available who have many years of knowledge available on many subjects.
We as a human species are very rich in available knowledge!
This is totally different from 1970 when I really started with electronics and by that I mean that I moved away from building radios from booklets and started experimenting with Power Supply's and transmitters.
Above all, keep building and experimenting, be very careful with assumptions, they are so easy to make and end up costing you a lot of time.
Kind regards,
Bram
