Hi again, and thanks for the reply. I am not sure I can actually use this dual volts / amps digi meter in this circuit. I managed to blow one up trying
I think the issue is having the 100V DC supply negative tied to ground *AND* the 12V DC regulated supply negative also tied to ground. I can measure amps by putting the shunt in the 100V DC positive supply wire, and running the meter off a battery, but it appears even with the black negative power supply wire to the meter floating trying to *ALSO* read the 100V DC + wire won't work.
For whatever reason the shunt in the negative 100V DC wire, before it is grounded, didn't seem to give an amperage reading.
I have a couple of amp only digi meters that read 0 to 50 amps, using the same 50 amps / 75mV shunt, but they need a 5V DC supply. I am now wondering how to test one to see if the 5V supply negative needs isolating from ground. I can use a 5V regulator on the 12V supply in the amp, but do I need to float it somehow above ground?
These things are neat, cheap as chips, but have complexities I hadn't considered over and above good old analogue meters! And hole sawing a round hole is a lot quicker than setting up to mill a rectangular hole with tight corner radii
