Can anyone suggest the best way to detect whether a mains wire is live or not from a low voltage circuit. Part of me had thought of using a hall effect sensor beside the wire, but that would only work when a significant enough current was flowing, whereas I'd be hoping to detect the presence of the 50Hz mains AC voltage whether it is powering something or going to an open circuited switch. I know that checking an "antenna" for 50Hz signals with lengths at large distances would have similar effects to short sections nearby). I'm thinking of a circuit I can put millimetres away from a typical UK style mains cable (the cable between the plug and a device, not the wires behind the wall, I'm not sure if they usually contain an actual shielding conductor or if earth stays as a separate strand, twisted round but not shielding the live/neutral pair) just to know if that cable is powered or not. I need to know reliably if the mains wire is powered or not, but don't need any analogue type measurements of actual voltage or current.
Thanks
