Depends ...
The maximum input voltage of the DC load must be larger than the peak value of the AC source,
the DC load must operate in "R" (Resistance) mode (not "I" / constant current)
and the DC load internal circuitry must be fast enough to follow the rectified AC waveform - you should verify this using a current probe and a scope.
