Author Topic: SMD capacitor markings  (Read 815 times)
Offline MikeKTopic starter
« on: April 25, 2022, 03:52:51 pm »
Looking for help identifying the electrolytics in the image.  The larger one appears to be 100uF/6V, right?  And the other is 47uF?  I'm not sure about the voltage on the smaller one.
Offline free_electron
    • SiliconValleyGarage
Re: SMD capacitor markings
« Reply #1 on: April 25, 2022, 04:14:27 pm »
correct
« Reply #2 on: April 25, 2022, 06:25:22 pm »
The "6A" on the smaller one indicates 6 volts?
Online Doctorandus_P
« Reply #3 on: April 25, 2022, 06:53:48 pm »
Probably not.
It's more likely that it's just an identification code, just like the "3A" on the larger capacitor.
If you then have the documentation from the manufacturer of your capacitors, it has a look up table so you can see what the specifications of the capacitor are.
« Reply #4 on: April 25, 2022, 07:10:11 pm »
There doesn't appear to be a manufacturer printed on the cap.  The device was made in Japan (about 26 years ago), but I looked at the datasheet for Nichicon caps and it doesn't seem to identify these markings.
The service manual for the device has a schematic, but...1) the larger cap is 47uF in the schematic and 2) the smaller cap is listed as 6V but also shows a test voltage of 6.3V at the positive terminal.
« Last Edit: April 25, 2022, 07:11:53 pm by MikeK »
Offline thm_w
  • Non-expert
« Reply #5 on: April 25, 2022, 10:29:09 pm »
« Reply #6 on: April 26, 2022, 01:07:39 am »
Okay, thanks.
