I've seen in more than a few places now something like this:
http://jahonen.kapsi.fi/Electronics/DIY%201k%20probe/In the places I've seen, it's always a 1k or 950ohm in series with the source, which gives 21:1 or 20:1 division when the scope input is 50ohm terminated. However, I'm just wondering if there's good reason to this choice of ratio? Like say 20:1 division would be too much for the signals I'm looking at and I don't have a low-noise pre-amp at hand (can be made ofc) - then would say a 10:1 ratio work - i.e., 450ohm instead of 950? Or 50ohm, to get 2:1? Or what about just straight probing with no discrete resistances other than the 50ohm terminator?
I'm guessing the biggest factor here is loading of the source? And 950ohm/1k is kind of a balance between loading the source and voltage division ratio?
