Attached are a schematic and a photo of a PCB is used in a simple power supply kit.
The kit included five diodes - all five look pretty similar. Three of the diodes measure 0.638 V and two measure 0.762 V. The PCB labels refer to three diodes as 4148, and to two diodes as 5V1. I'm pretty sure the 4148 diodes are the three that measure 0.638 V. What I can't quite figure is why the other two diodes, the "5V1" diodes, measure 0.762 V. Maybe this is normal and it's a non-issue or maybe the kit included the wrong diodes? What are the normal distinctions between a 4148 and a 5V1 diode?
Thx
My understanding, is that, in order to make zener diodes (things also change, depending on what voltage the zener is designed for, e.g. <= 6.3V (approx), but I'll leave that for another discussion), rather than normal diodes, such as the 1N4148, they have to change the doping of the semiconductors. That (and maybe other process changes), results in the higher Vf (forward voltage drop), you are measuring.
tl;dr
Yes, it sounds normal, to find slightly higher voltages, in those circumstances.
So, 0.638 V for the 1N4148's, and 0.762 V for the zeners, sounds about right to me.
