Hi everyone,
im a beginner in electronics, and im currently working on a project and need a little bit of advice. I have a 555 timer circuit which creates a pulse, i need to break that pulse into two seperate signals, however the 2 set of pulses need to be delayed by 5 pulses...
for example
1 2 3 4 5 6 7 8 9 etc
0 0 0 0 1 2 3 4 5 etc
any ideas on the best way to do that.. I was debating using some sort of logic and relay, but im sure there is an easier method.
once the fifth pulse on the first signal is recieved, i need the second set of signals to activate from then on as well.. so both lines will be creating a pulse from the 555 timer, but the second line cannot start until the first five pulses have been processed..
thank you for your time
keith
