logic lvl out XO. see spec sheetMCU..see spec sheet.both MCU, XO must use same VC 3.3 or 5V, and ground.MCU may have option pin for bare xtal or XOj
Is it still good practice to add caps?
I'm using this for a project: https://www.digikey.com/en/products/detail/ecs-inc/ECS-2100AX-100/827269What I want to know, and the datasheet is unclear on, is whether I need any external components. This will be the clock input to a MC68000 CPU. Is it still good practice to add caps? Do I need any sort of buffering or waveform shaping circuitry? It will be here tomorrow from Digi-Key, so I can do some tests with my oscilloscope, but all I have are solderless breadboards to test and that is fraught with issues.Are there any best practices, or do I just simply slap on power and ground and run the output to the CPU?
