Don't think those are selenium, they never had a shiny anodised aluminium plate, more a lot of steel plates for cooling with a paint on them.
mor clearer pictures of the sides and all angles will help, that might be a split charge controller for a car, or some other device. In any case 400V 2200uF capacitors are more commonly used in high power inverters, a 2200uF capacitor in a car is typically only rated for 25V, and is quite small. Those 400V ones will be as large as your hand each, with screw terminals on the top.
